I have a small block 340 came with a ATI balancer, pulley's don't lineup so I need to switch to a stock balancer. my question is are the balancers universal will they fit both cast iron and steel crank style?
Race dampers are spaced to work with a 1/4 inch motor plate.
so should there have been a ati on in the first place seeing I have a cast crank, and the ati is for a neutral balance/steel crank??
Well that's just it, I don't know what the correct pulleys are, that's why I'm reaching out for help.Depends on how the balance job was done.
Bite the bullet and buy the correct pullies. They are out there. Better off with a good dampener and needing to buy pullies than to put a stock one on just to use stock pullies.
OP, you are on the right track for questions... and a possible can of worms in seeking answers: the only 340 ATI damper listed in the link from 70aarcuda is for the internal/neutral balance setup.so should there have been a ati on in the first place seeing I have a cast crank, and the ati is for a neutral balance/steel crank??
The engine is currently on an engine stand I pulled the oil pan looked at the crank it has casting marks on it so I assume it is a cast crank the Pistons I believe our speed pro Pistons the rods look stock it is a four-speed car so it has a clutch. I purchased the car with this engine and transmission combination already in the car . I can post some pictures of my alignment issue laterOP, you are on the right track for questions... and a possible can of worms in seeking answers: the only 340 ATI damper listed in the link from 70aarcuda is for the internal/neutral balance setup.
IF the engine was balanced for the stock cast crank 340 balance setup, then there should have been a correctly imbalanced damper for a cast crank 340 on in the first place (not an ATI from the list posted), along with an inmbalanced flex plate (or something simulating the imbalance of the TC for the cast crank 340).If this was the case, you could pull off of the transmission inspection cover, slowly turn the engine, and look for either a 'bite' out of one edge of the flexplate, or a rectangular steel weight welded on the front surface of the TC near the outer edge. I would do this regardless of anything else at this point.
BUT, if you have much lighter pistons and rods than stock, then the 340 cast crank could have been balanced for neutral balance damper and flexplate/TC. (No 'bite' out of the flexplate nor any extra weight welded on the TC.)
SO, do you know what pistons and rods are being used? And do you know for a fact that the crank is a cast one? Even if it has a later 340 block, someone could have put in an earlier forged steel crank, and used neutral balanced damper and flexplate/TC.
Do you know the shop that balanced it? That would be the fastest way to know for what parts the crank was balanced.
Are you having vibration issues?
The car has no power steering just a belt for the crank water pump and alternator thank you for your informationI'll look at the receipt tomorrow and tell you the place I found mine. You take a measurement from the face of the water pump down to the face of the dampener and they'll hook you up with the correct pullies.
It's certainly easier if you don't have power steering but it's doable.
I'll let you know tomorrow.
Thank you for the information I will be pulling oil pan off sometime tomorrow.IIRC, it should be right there on one of the throws; I don't have one handy to check. When you say the crank has casting marks, are they a very, very thin ridge at the parting line? (Like shown in the 4th photo in this link? Cast vs forged crankshaft)
And you can see the rod casting numbers; they will be on one of the wide sides of the rod beam. (Sorry, I thought you still had the pan off....)
Are the TC and flexplate easy to see?
I don't know the builder, I bought the car from a widow.she did not give me any info car.who sells pulleys for a thicker damper? try and contact the engine builder and see if it was internally balanced
