Has anyone used a Ford Magnum T56 behind a LA engine?
crawsfire
TX
Just use the right spline clutch and make sure the input shaft length will work? Not sure. Any first hand experience? Thanks
Get the right scattersheild.
I dont see it listed for ford but you can swap the input shaft for ls or viper. Its an undertaking though.
Thats all i know
Is this the one where the gearbox is damn near as big as a Mopar SB?
Check out the bulge in the Overdrive section. That is right where the T-bar crossmember Hoop is on an A-body. Major re-engineering looks to be required.
Jus saying.
Unless it's all a screaming deal, I'd be looking at the TKX 5 speed. Smaller case and standard muncie bolt pattern I believe. Should be a much easier install if you're not dead set on that sixth gear.
If anyone is wondering. You use the quicktime RM-8078 bell and the hyd throwout bearing for a Ford T56. The Ford T56 and the LS1 T56 to GEN 3 hemi use the same bell.
Use hydraulic T/O bearing, Tilton 6000 Slip-on for Ford T-56 Magnum, flat face bearing
(1.78")
