HDK Small block advice needed
dodge71demon
Indiana
For those of you that are using the HDK system with a small block what shocks and spring rate coils are you using not looking to slam my car possibly a little lower than factory -Thanks
Hi Rod,
If you are switching from a big block to a small block and like the front end height now.....the ONLY thing that might need swapped is the spring (rate) simply because a similar equipped small block will likely weigh less.
The spring holds up the car (weight) , the shock only controls (dampens)] the bounce.
Please keep in mind when comparing components with other builds, tire diameter is a major factor
I may be going back to the 2" drop spindles -- have the scamp taken apart as far as it's going starting the Valiant teardown on 1-16
