MiradaMegaCab
SCE Gaskets have an integral O Ring built into the head gasket.
Patented Integral Combustion Seals perform the function of O-ringed blocks and heads without the added machining costs. They also provide extra sealing in high combustion pressure environments where rules prohibit O-ringing. The ICS Titan features stainless steel O-ring wire inserted into the gasket body around the cylinder bore, with combustion pressure forcing the flanges against the head and block for a self-energized secondary seal. Coolant and oil seals also included.
Has anyone here used 0-rings with a MLS gasket? How about the 1008 or even copper?
My 383 was originally built before all these fancy gaskets were around (1993) so I would imagine that's why it was o-ringed.I'm not pro or anti any gasket. I might just use copper with the o-rings or???
W-2 heads btw.
It will be some time before this thing gets screwed back together... $$$ is pretty much non existent right now.
