Head/manifold porting question
sublimeswinger
SUBLIME Senior Member
Santa Clara,CA
This maybe a dumb question but here it goes. If i were to port match my manifold, what tool would i use to do this? can you use a Dremmel? or do you have to use air tools?
Look at ferinacarbide.com and get the 4 flute carbides for aluminum and a dremmel tool will cut too fast so use air and run it as slow as it will go as most of the air tools are too fast, so a regulator for the air line will be needed or get a tool that has one built in. Also keep it lubricated or the carbide will dull quickly.
You can get an electric Die Grinder or an air one. I bought an electric one from Harbor Freight for like $39 or $49 dollars. There are abrasive kits for heads also from Summit, Mancini, etc.. One other item I bought was a speed control box to go between electric outlet and die grinder to keep rpms in operating range of abrasive tips. Check link below for some good tips on porting heads.Mike
http://www.sa-motorsports.com/do-it-yourself.aspx
