I don't know why 'n hell anybody would remove the dimmer switch. I also don't understand, unless the wiring has been further hacked, why the hi indicator would be lit
Headlight wiring is pretty basic, but you might consider installing relays and if not, halogen lamps
You have a shop manual?
Crackedback on here has a relay kit
The original circuit brought power off the headlight switch, and fed down to the dimmer. One of the two remaining terminals of the dimmer would be "hot" and switch when you tromp on the switch. The hi beam wire branches off and feeds up to the dash
The hi and low power wires come off the dimmer, go through the bulkhead, and feed the lamps
Shop manuals, although 72 is the newest you can download free, and wiring might be some different:
http://www.forabodiesonly.com/mopar/showthread.php?p=1970088617
MyMopar has a bunch of stuff including manuals (but not 73) and simplified wiring diagrams
http://www.mymopar.com/index.php?pid=31
and read these articles
http://www.madelectrical.com/electrical-tech.shtml
on headlights:
http://www.madelectrical.com/electricaltech/brighter-headlights.shtml
and this one, on the problems with bulkhead connectors and the ammeter circuit
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
