breakstuff
Can a headliner be successfully installed without removing the rear window?
If you want to install a headliner properly in an early A, I would
recommend having both front and rear glass out of the car. The
headliner material is glued to the pinch welds front and rear. This
procedure would be the same for almost any 50's, 60's or 70's car
that use rubber gaskets to seal windshield and back glass.
I disagree. As it may be more like the factory did it with the windows out, the headliners that I have put in were done with the windshields out, but never the back window. The original headliner wasn't under the back window on either car and I could hook it up easily on the little hooks back there. They have both been in the cars for over 15 years.
Note that here are barbs throughout the front & back windows (under the gaskets) which the headliner hooks to. Virtually impossible to do correctly with the glass installed.
