Sean,
Had a nice conversation with you today, and after we had talked you could easily run what you want with a good set of ported LA heads, 10.50's and 10.60's shouldnt be a problem. But will take the right chassis setup and I believe that you have this undercontrol.
The money that you will spend on the aftermarket heads plus the porting work will run you in the $2,000.00 - $2,500.00 range plus the valve train, I could do you a good set of LA's for $500.00 - $700.00 less complete less rockers and shafts. I would just have to know which engine you're planning on putting these on as they all take a different head combination. Port size, volume, and air flow, and valve size. Also will need the RPM's that you're planning on turning the engine and valve lift. Look forward to talking to you again soon.
