64dartwagon said:I would suggest running your headlights off of relays. This way you get a direct pull off the battery and not thru the fire prone bulkhead connector. I would suggest this for any older car as it's just safer and the headlights tend to just be brighter this way. They get the full voltage/amps.
Sublime69 said:the HIDs are only 35watts. I just want to make sure it will be fine to use the stock wiring?
