Heat sinks
nuttyprof
York, Nebraska
I have an assortment of heat sinks if anyone is interested in them for an HEI conversion. Pics below.
The sheet aluminum one has broached bolt holes spaced right for a 4 pin HEI module.
More heatsinks. The second heat sink down (4th pic) is also drilled at the right spacing for HEI.
Nice offer. I used an old CPU heat sink on my slant HEI setup. I bolted it to the inner fender and put tapped holes in it to hold the module. That way the module can be easily swapped on the road if it fails. I still have a piece if I ever do another HEI.
Make offer. I got them just for pulling them. Not looking to make of money but would not mind getting a little bit.
The one 17 down from the top looks good for for my COP ignition. It is a rail with several clips. How many can you supply? The plan is to use one for 4 and 6 cylinder engines, and two for V8, one on each bank.
That is a nice offer, and I hope people realize those are MAJOR overkill for HEI modules.
Keep in mind that the modules ran in 200+ degree distributors so any environment temp less than that is plenty safe for them.
Probably more than half a dozen. I do not get a lot of them but I grab them when I can. Number 16 is an end view of the same peice.
