spl440
Everybody's Fool
Have 67 Dart with mild 360 with 4 speed stick. Seems that when I shift it above 6500 RPM, and back off of it, I either have a hose come off, or blow out the heater core. has happened about 4 times over the last 3 years. The motor does not have a blown head gasket, standard pulleys, standard water pump and thermostat. Would a high flow thermostat help? Since it happens usually after I back off from a higher RPM, was thinking it has to much water flow can not even out in time so it pops a hose or blows the heater core. Factory bypass is there.
