Hello
Seizure66
New Member
Northern Arizona
Hello folks,
I am new to this forum. Looks like a ton of good info around here. Thanks for having me. So, I have this 68 Barracuda convertible. Motor for the top is super slow, so slow in fact it won't lift the top without assistance from me, while the kid holds the toggle. So, I have no shop manual yet, can anyone assist with a pdf, or other resource on the details of this motor, fluids, access etc.? Thanks all. Will catch up to ya soon.
~Seizure
If you pull the back seat you can access the motor and pump. Unplug it and hook up a wire from the positive of the battery to either contact on the connector. One is up and the other is down. If it operates at normal speed then you just have a wiring problem. It could be the switch or one of the connections. If the top pulses going up you are low on fluid. If you hear squeaking from the hinges try lubing every joint you can find. Does it come down OK?
Welcome aboard :happy10: IMO the best darn site on the net 8)
There are some great folks and tec's here that will jump in and help us along
Very nice 68 Barracuda Convertible, do you know your color code on it off hand ? I need a color for my Valiant.
And the country around you sure brings back some great memories
and looks like you have some good help with you.:happy10:
Welcome, another 68 Cuda convert, way cool. Just a little bias.:cheers:
