HELP!! 360 Engine with transmission and headers?
Small Block Mopar Engine
  1. 67DodgeDart360
    67DodgeDart360 Well-Known Member
    156
    41
    Nov 8, 2015
    Maryland
    Local Time:
    4:18 AM
    Yesterday I put in the 360 engine with transmission and tried to put the headers in and I couldn’t fit them in. I have a 67 Dodge Dart. How do I put the headers in? Do I put them in the car before putting the engine and transmission in? Or can I put the headers in after? I appreciate the feedback.
  2. 67DodgeDart360
    156
    41
    Nov 8, 2015
    Maryland
    Local Time:
    4:18 AM
    If you have any pictures please Post them. Thanks
  3. RustyRatRod
    RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
    60,795
    32447
    Jun 7, 2010
    Georgia
    Local Time:
    5:18 AM
    Read the instructions? Always works for me.
    • Like Like x 2
    • Wyrmrider
      Wyrmrider FABO Gold Member FABO Gold Member
      3,367
      1601
      Sep 5, 2016
      los angeles
      Local Time:
      2:18 AM
      which headers
    • 67DodgeDart360
      156
      41
      Nov 8, 2015
      Maryland
      Local Time:
      4:18 AM
      Long tube headers.
    • 67DodgeDart360
      156
      41
      Nov 8, 2015
      Maryland
      Local Time:
      4:18 AM
      What instructions? They came with the engine when I bought it.
    • 67DodgeDart360
      156
      41
      Nov 8, 2015
      Maryland
      Local Time:
      4:18 AM
      These are the ones I have.
    • RustyRatRod
      60,795
      32447
      Jun 7, 2010
      Georgia
      Local Time:
      5:18 AM
      Look up the Hedman headers for your car on Summit. They have a PDF link to the instructions.
    • Wyrmrider
      3,367
      1601
      Sep 5, 2016
      los angeles
      Local Time:
      2:18 AM
      do they have a name or number on them?
    • MoparMike1974
      MoparMike1974 FABO Gold Member FABO Gold Member
      2,320
      1623
      Jun 16, 2017
      Maryland
      Local Time:
      5:18 AM
      In my experience, those cheaper headers require them to be placed in the car first then the engine dropped in. The steering linkage goes through the header on the driver side. This will require removing the tie rod end from the drag link.
      Where are you at in Maryland?
      • Like Like x 1
      • Unconventional
        Unconventional Well-Known Member
        9,621
        9273
        Apr 17, 2017
        Santa Maria, Ca.
        Local Time:
        2:18 AM
        Aside from the drag link issue that wasn't mentioned in the instructions from Hooker I had to undo both motor mounts and jack it up until the bell housing was against the firewall, then fish the driver side in from underneath. Passenger side went in first with the aid of the short oil filter. '72 Swinger column shift. Don't even think about Purple Hornies th?id=OIP.jpg the crossmember won't allow it :BangHead:
      • fklskv
        fklskv Well-Known Member
        1,135
        591
        Aug 14, 2011
        Lackawanna, NY
        Local Time:
        5:18 AM
        Tti headers slide right in from underneath.
      • flyfish
        flyfish C8H18+N2O = :-D
        1,984
        555
        Apr 16, 2007
        Indy
        Local Time:
        5:18 AM
        The ones I have used over the years had to be laid in place before dropping in the engine (both race headers and cheap-O's). You can probably just lift the engine up a little with a hoist and get them in...hard to say without looking at it.
        • Like Like x 1
        • MoparMike1974
          2,320
          1623
          Jun 16, 2017
          Maryland
          Local Time:
          5:18 AM
          You can jack the engine up to get them in but I found its much easier to put the headers in first then drop in the engine.
        • Projectile Dart
          Projectile Dart Well-Known Member
          117
          75
          Jun 30, 2017
          Long Beach, CA
          Local Time:
          2:18 AM
          those look similar to my no name headers that came with my dart. As stated above, my steering goes right through the middle of them so that has to partially come apart to get the headers in/out. That being said, at least with mine, they had to go in from the bottom and I got them in before the engine was in, it might work if you just pull the engine up a bit but I don't think mine would ever fit with the engine sitting on the mounts
          • Like Like x 1
          • Dave 74 Dart
            Dave 74 Dart Well-Known Member
            386
            632
            Jan 24, 2019
            Southwestern Ontario
            Local Time:
            5:18 AM
            Swapped out my son's headers last year in 70 swinger. Installed tti long tubes, had front end up 2 1/2 feet( car blocked and supported accordingly ) . Had the steering box out as we were swapping it as well, power steering pump, battery, steering linkage removed. Drivers side slide up from bottom and passenger side went down easy enough. Not a fun job but wasn't terrible.
          • MoparMike1974
            2,320
            1623
            Jun 16, 2017
            Maryland
            Local Time:
            5:18 AM
            TTI headers are no comparison to the ones in question as far as fitting them. Steering box, starter and brake booster all get in the way. Unless you remove all these items first it will give you a fit trying to install them. If the engine is out the simplist way is to drop the headers in first. You will need a friend or two to hold them up out of the way and ease them in as the engine drops in.
          • abodyjoe
            abodyjoe Well-Known Member
            20,659
            5803
            May 22, 2004
            Berlin,N.J. 08009
            Local Time:
            5:18 AM
            Passenger side should be easy. Driver's side you'll have to pop the steering linkage apart, get the car real high in the air, lift the motor off the mounts a few inches and install from the bottom.
            • Like Like x 1
            • Agree Agree x 1
            • dustertogo
              dustertogo Well-Known Member
              699
              53
              Mar 7, 2006
              Brandon, MS
              Local Time:
              4:18 AM
              Yep. That's the way it's always been and always will be on A bodies!
              • Like Like x 2
              • Divenut
                Divenut Well-Known Member
                3,060
                1354
                Sep 22, 2011
                Naperville Illinois
                Local Time:
                4:18 AM
                I have to get the car up high (2+feet), to get my old Hooker Comps to slide in. Gotta get enough ground clearance to slide them straight up. That's the trick. Tight fit for sure, but they do slip in. Helps having someone on the topside pulling and guiding them in. Of course, got to disconnect steering linkage. I don't have to mess with the motor mounts, but after putting in new, un-squished mounts, the job is easier still.
                Be well,
                Pat
