superdart426
Banned
PLEASE,what are the best factory heads to use and i need a crank will a440 crank work?? this motor is a RB correct,and where can i find some .030-.040 pistons,,thanks in advance for any help given,,sd340:burnout:
do u have a full casting # for the hp 915?? and a casting # for max wedge heads?? thanks sd340 quench motor??the 67 915 heads are the best (not counting the max wedge)they are close chamber. they came in two versions HP with a 1,74 exh valve or standard with a 1.60 valve, ports are identical and flow the same as the 906, nice for setting up a quench motor,
Probably better off finding a core 440 with steel crank and hopefully a decent set of heads.
