I would like some advice on a cam for my 78 w200the engine has been rebuilt and i just need to choose a camshaft. It is a stock rebuilt on a 78 440 engine so its still low compression only non stock item are the heads they are 516 heads updated for unleaded gas so i figure with thin head gaskets ill be maybe 8.5 to 1 compression but may be lower. Running 4.10 gears 32 inch tires and a 727 transmission i have not picked a torque converter yet so no stall speed info.
The truck is not for racing or big 4X4 off roading mostly street driving and probably daily driver to work int he winter snow. I just want to to run healthy and i like having a smooth idle, i may add a Holley sniper fuel injection in the future if that make s a difference on choice.I have a new set of stock replacement valve springs so if i can get a cam that will work with those that would be great.
Here are a few of the cams i am looking at suggestions of other cams are welcome i am no cam expert..
Hughes Engines
Voodoo Hydraulic Flat Tappet & Lifter Kit - Chrysler 361-440 Three Bolt 250/256 - Lunati Power
https://www.summitracing.com/parts/HRS-720021-11
https://www.summitracing.com/parts/sum-6400/overview/make/dodge
https://www.summitracing.com/parts/mel-mtd-2/overview/make/dodge
http://www.hughesengines.com/Index/...dWxpYw==&level3=U3RyZWV0L1N0cmlw&partid=30250
Hughes Engines
