Help! Edelbrock 3275 Streetmaster for Chrysler 318
Bossman
San diego
Hello,
Does anyone know if this edelbrock Streetmaster 3275 will fit a 72’ 318? Or am I better off selling it and getting a newer version?
Thanks!
Pics of manifold and ports. I'm not finding much on this one.
I just saw a few pics. It will work but not the best. Low rise, open plenum. About like the stock HP273 intake. The old LD4B is a better intake I think. A dual plane works better with teens on the street.
That is not that great of a manifold, but it will work if you are just changing from a 2bbl to 4 bbl.
Ok thanks. Yes that’s what I was going to do just to get car running again and while I restore it until I start upgrading everything.
You will be fine, just bolt a square bore carb on it and be done.
I am really liking the new 625 street demon carb, it a bolt on, slight adjustment carb, for a daily driver.
Way better than any eldebrock, for the same price.
Oh cool. I’ll have to check it out. I have a edelbrock carb but it’s a marine carb that fits it. Someone told me it may work just while I mock everything up and then switch it out.
Yes, if you just need something to get it running the intake and carb should work. You may have to engineer the throttle and trans. kickdown but a new intake and carb won't help you out there.
