help -how do i remove wire from side marker housing
73dart360
fort lauderdale
usually you can push in and twist ,doesnt work ,there are 2 screws on the front marker side i removed them it didnt help
You cant.. i believe front signal conectors are built in as part of assembly. The bulbs can only be replaced by removing the lens on front
Up under there follow the wire isa connector underneath connected to the front valance
If you already remove the backing plate being held on by those two acorn nuts just push it out
ok - you want to paint THAT piece- the light housing itself!?? so you want this (inside the circle) off
- it is "swedged" on and is not meant to be removed - best you can do is tape over it
ok - you want to paint THAT piece- the light housing itself!?? so you want this (inside the circle) off View attachment 1715032676
i want to pull the wire out so i can take the housing off the car so i can paint the car,I cant pull the housing thru the hole
