A few weeks ago i removed the gauges from my car. when I put it back in I had no power to anything. It finally started working after I took it out and put it back in about 10 times,
Today I removed it again to replace the voltage limiter and again I have no power.
I have 12 volts at the red wire and 12 volts at the black wire so the alternator gauge is good. Everything else is dead.
It is grounded by the 4 screws that fasten it to the dash but nothing will work.
Any ideas what I have done wrong again?
This is a 65 Barracuda so there are 2 wires, the red and the black, the plug that plugs into the back of the gauges and the wire plug to the ignition switch.
thanks for your help.
