7demon2
Registered User #1824
well as the title says i might have made a mess of things. what i did was try to pull off a steering wheel the wrong way ( without a proper puller ) what i ended up doing was getting it off but in the process i pulled the steering shaft out of the coupler from the steering box! is this now ruined or can it be fixed? what do i need to do to fix it? i tried to tap the shaft back in but no luck.... below are the pics of my mistake. also in looking at the column adapter i have i noticed the ring on it dosen't have the little upper piece on it like the original wheel did. should this be there? if so can i take it off the old wheel and transfer it to the adapter?....help!!!
