Help me identify this early 904
Redneckrodshop
New Member
Pawtucket, RI
The numbers stamped n the pan rail just below the linkage appear to be :
246442911. 1066111. It has the second cable for the parking pawl, which leads me to believe it's a pushbutton shift, 65 or earlier. It has the 4 bolt flange on the output shaft.
Can anyone decipher the numbers and tell me what this is out of?
Thanks for any help!
1965 and older had the 4 bolt flange output for the ball and trunion front u joint. ^5 was the last year for the pushbutton transmission. I have a part number book. I will see what I can find. tmm
65 and earlier 904 based on the shaft. I have one exactly like in my 63 Valiant 225.
Jake
My book only lists v-8 transmissions but the number sequence tells me it's a 64.
