I have had this engine and 727 trans in storage in my garage for 25-30 years. I am not going to use it as I had intended and will be selling the pair. My problem, I can not seem to pin point what year the block is. it is definitely a 360, Forged in Toluca. I know it came out of a pick up and is a running engine. Vehicle was totaled in the rear. Right side of block 4315830-360, Vin pad on oil filter side is blank. picture of numbers is drivers side under cylinder head at front of block. I am at a lose and do not want to misrepresent this engine to a buyer. motor is water pump to flex plate and oil drain plug to air cleaner. Buy the way, It has a Rochester quad. 4 bbl. on it. I am attaching a few pics of the block, if there is ANYTHING you can tell me or point me in the right direction it would be much appreciated!! Thank you very much Tim Thompson
