Help, Quarterstick Neutral Safety Switch
Chris3racing
Active Member
Anyone wired up the switch Hurst has for this shifter? I have the Hurst switch on the shifter; however, it is not hooked up. The switch from Hurst shows two female wire connectors in the kit. Where do they attach to the switch. We do not have the instructions for the shifter and/or switch. Thanks.
I didn't use the quarter stick switch, looked pretty hokey to me. I just used a stock starter relay and and the stock neutral switch on the trans.
Yep, Mr Jones is right just use the stock switch in the trans. The reason Hurst includes it in their shifter is for the GM boys. Most of their switches are in the column or console so they need the switch.
Chuck
I did the same, and pulled the Hurst switch off all together. you need to disasemble the shifter, but its pretty easy
