OK everyone, lets think about this being it is no longer the original engine in the car.
The 360 is an externally balanced engine.
The 904 automatic behind it needs the weighted converter to work correctly with the 360 with the stock mopar flex plate, or the half moon cut out after market flex plate to make up the indifference in balance to work with the 360.
Lets say he has the stock external balance 360 crank with a non-weighted 904 converter. Maybe it was an old 318 car with this 904 non-weighted converter.
Anyhow running that 360 with a non-weighted converter will set up all kinds of vibrations especially at the trans front pump bushing wearing it out, from the converter being out of balance.
Creating the Knock that you are talking about. 3/4s of the people on here are saying it's flex plate problem. Think it goes in a little deeper to a bad trans front pump bushing and or a cracked torque converter hub. From it being out of balance.
OP is saying it makes more noise in Neutral than in Park, that is because the front pump is only pumping when it is in neutral or in gear, not park. So if the front pump bushing is out it is going to make a lot more noise when it is under load pumping in Neutral, than when it is freewheeling in Park under no load.
My Vote:
Bad transmission front pump bushing.
My Vote:
