ccsbivens
Hi there, my name is Christian and I decided to join this forum for some help.
I have found in the past for forums to be very helpful in understanding and finding solutions to a problem to a car I am new to, so heres some background.
I bought a 1974 Dodge Dart 2 door Swinger Saturday for 250$. The Slant six turns over by hand and has compression, goes in and out of all the gears, and the body is in dang good shape considering. The only reason he was selling so cheap is cause of a recent handicap and the fact he had 198 cars he had to get rid of. The first issue we came across was no keys. I popped the lock out, and unlocked it and the door still wouldn't budge. So what I did to get inside to put it in neutral to load on the transport was jimmied the window down an inch, pryed it out just far enough for me to reach in and roll the rear window down and I crawled in. I then tried to open the door from the inside with no luck, so at the moment I'm Duke'n it.
The car is home now, window down, and I live in Tacoma. It rains 8 days a week here. So that door needs to get open. I removed the door panel and began my assessment. The door handles were actuating the latch, and were in fact moving something. I assume it was moving what it was suppose to be moving, this is the first time I've had this issue so my understanding is vague. My first thought was rust, however the latch mechanism itself is still silver. So I sprayed it with PB blaster just in case the internals were another story for the last 48 hrs going out there periodically and giving the door some pretty harsh kicks with the handle pulled. Still no luck. So I then called my dad. He explained that the door would have to be rusted beyond belief for it to not open after kicking it, and he mentioned it may not be unlocking. So I checked that again. The locking mechanism is moving, but I don't know if its moving like it should. After all this examination and tinkering, I've come to a conclusion.
The door is unlocking, but it looks to me that the hook that grabs the striker is not rotating as far as it should. It rotates, but it stops at a point however the handle still wants to pull it farther. So in my perception, something is preventing it from rotating
I would like to refrain from calling a locksmith out, I'm not even sure if this is even something he can fix. So what do I need to do? What are your takes on whats going on? And what are some solutions?
I've tried to find info on this latch on the internet with no help, so if someone can provide a blown up schematic of the latch assembly it would help a lot to strengthen my understanding of this mechanism. And if theres anything I can do on my part to help you guys help me, let me know. I need these doors to open so I can stop the car from being flooded!
Thankyou, Christian Bivens
