Help with 4 speed trans install
Manual Transmission & Clutch Discussions
  1. Veryfastdart
    Veryfastdart FABO Gold Member FABO Gold Member
    459
    77
    Feb 28, 2010
    Hampton NH
    Local Time:
    4:35 PM
    I have a 69 GTS 340 4 speed. We call it the "Bastard Child", It was purchased as a disassembled basket case. The issue is I installed the bellhousing and it fit flush on the block. I installed the transmission and it wouldn't go all the way in the bellhousing. It was out about an 1/8". The crankshaft has a new needle bearing in it. The clutch was installed and aligned. The transmission was in neutral and the tailshaft turned freely, until I tightened up the 4 bolts to pull the trans into the bellhousing. I then heard the "POP", I just cracked the aluminum bellhousing. "DAMN"! I pulled the trans out and the bellhousing off, located the crack, TIG welded it and tried to re install it. Same problem, 1/8" gap and it stops?? The tail shaft turns freely, UNTIL I tighten it again, now the shaft will not turn?? Also the bottom of the bellhousing pushes out the 1/8" that the transmission would not go in.
    I assume the input shaft is hitting the end of the crankshaft?? I'm going to remove it AGAIN and cut the tailshaft down. I will measure from the inside deepest point of the crankshaft to the outside of the bellhousing. My question is, IF this is the issue, How much should I cut off? My gut feeling the 1/8" that it won't go in now plus a 1/4"?? So 3/8"??? thanks
    • Like Like x 1
    • Daves69
      Daves69 Well-Known Member
      4,184
      2213
      Feb 20, 2011
      WestOfChi
      Local Time:
      3:35 PM
      I believe 1/8" clearance is plenty..
      FWIW, Here's some numbers I came up with for a 440 with a steel auto trans crank and un-cut trans input...…...
    • Veryfastdart
      459
      77
      Feb 28, 2010
      Hampton NH
      Local Time:
      4:35 PM
      Thanks Dave
      So your saying 1/4" will be fine?
    • j par
      j par Well-hung Member
      13,771
      6378
      Jul 2, 2014
      Portland Oregon
      Local Time:
      1:35 PM
      It sounds like a bunch of unknown Parts going together wrong. Possibly, I know this sounds labor-intensive, but trying it with a different or a testing bell housing. Maybe someone else will step in, but I've never heard of anybody having to cut the end of their perfectly good transmission off in a stock application.
      • Agree Agree x 1
      • Veryfastdart
        459
        77
        Feb 28, 2010
        Hampton NH
        Local Time:
        4:35 PM
        I'm not sure the crank shaft was drilled for a 4 speed? But the Needle Bearing went in, so maybe it was? Maybe just not deep enough? I have heard of plenty of people cutting the input shaft, I agree, I shouldn't have to, but I don't know what else to do?
        • Like Like x 1
        • Agree Agree x 1
        • skep419
          skep419 It's only money, you can always make more
          3,539
          1175
          Sep 18, 2008
          Minesoooota
          Local Time:
          3:35 PM
          correct bearing retainer?
          • Agree Agree x 2
          • Garrett Ellison
            Garrett Ellison Amateur driver on public roadway, do not imitate..
            1,275
            871
            Jan 1, 2018
            Southwest VA
            Local Time:
            4:35 PM
            Yes, but only using the aftermarket pilot that fits in the converter register on the crank. If the crank doesn't have a pilot bearing hole in it but has a retrofit roller bearing but in the converter register then the pilot should be trimmed back to give about a little air gap between the end of the crank and the pilot. You only need enough pilot to go all the way through the bearing.
          • Daves69
            4,184
            2213
            Feb 20, 2011
            WestOfChi
            Local Time:
            3:35 PM
            ^^^ See skep419 post. Did you test fit?
            Per MP, all the stock bells are 7.380". Then too, a block saver from a previous scatter shield setup might be the gap you are missing.
            You'll need to measure your set up to know exactly what you have. Measure twice, cut once.
            • Agree Agree x 1
            • Avispa
              Avispa FABO Gold Member FABO Gold Member
              690
              150
              Feb 26, 2007
              Georgia
              Local Time:
              4:35 PM
              So that would mean the pilot bushing hole would have to be at least 1.245 in the end of the crank, right, might be a pain, but could you mock up all the components out of the car (except the motor of course) add the numbers and then measure the depth of the pilot hole, and add that also, them measure the assembled mock up. and make sure the needle bearing is fitting on the trans input shaft right. Just some thoughts, been outta the game a while.
              • Like Like x 1
              • Veryfastdart
                459
                77
                Feb 28, 2010
                Hampton NH
                Local Time:
                4:35 PM
                Thanks for all the comments, I'll measure twice, cut once! I'll let all of you know how I made out next week!
                • Like Like x 1
                • Daves69
                  4,184
                  2213
                  Feb 20, 2011
                  WestOfChi
                  Local Time:
                  3:35 PM
                  And indicate that bell in!
                • Avispa
                  690
                  150
                  Feb 26, 2007
                  Georgia
                  Local Time:
                  4:35 PM
                  Yep, I have forgotten the procedure, but Ya use a dial indicator to precisely align the trans and the pilot hole, if it's offset, ya use offset dowels to center the bells trans hole and the pilot hole.
                • RAT ROD AL
                  RAT ROD AL I know just enough to be dangerous FABO Gold Member
                  1,552
                  1330
                  Jan 18, 2013
                  St. James City. FL.
                  Local Time:
                  4:35 PM
                  " I'm going to remove it AGAIN and cut the tailshaft down."
                  Why are you wanting to cut the the tailshaft when it's the input shaft having the issue ?
                • sireland67
                  sireland67 Well-Known Member
                  8,132
                  2173
                  Oct 27, 2010
                  WV
                  Local Time:
                  4:35 PM
                  With a crank not drilled, about 5/8" off the input shaft will work.
                • Veryfastdart
                  459
                  77
                  Feb 28, 2010
                  Hampton NH
                  Local Time:
                  4:35 PM
                  I hope so, the guy doing the car with me has been at it for 50+ years!
                • Veryfastdart
                  459
                  77
                  Feb 28, 2010
                  Hampton NH
                  Local Time:
                  4:35 PM
                  Sorry, good catch, meant input shaft! Long day at the Firehouse!
                  • Like Like x 2
                  • Veryfastdart
                    459
                    77
                    Feb 28, 2010
                    Hampton NH
                    Local Time:
                    4:35 PM
                    Yes, I think that will work Sireland67! Thanks
                  • AJ/FormS
                    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
                    16,062
                    4890
                    Jan 19, 2014
                    South-Central Manitoba,Canada, 900ftelevation
                    Local Time:
                    3:35 PM
                    I've never used a needle bearing pilot, and I don't think I ever would. I think it would eventually wreck your input shaft. IDK, but there's at least two better ideas, IMO.
                    • Agree Agree x 1
                    • TheGrateRonzini
                      TheGrateRonzini FABO Gold Member FABO Gold Member
                      483
                      393
                      Oct 25, 2017
                      Western New York
                      Local Time:
                      4:35 PM
                      I had a hydro lock issue similar to this. I put grease on the input bushing when I put it in, and I must not have cleaned out the hole. I couldn’t get the trans to go all the way in no matter what. Hammers, tightening the bell bolts one at a time, nothing. I cleaned the pilot hole and she slid in like butter off a hot biscuit
                      • Like Like x 1
