I thought I had finally found what I was looking for when I saw this pic in the spitfire headers thread. I wired my alternator up the same and its still not charging. I've deleted the old black box voltage regulator and wired it every way under the sun but can't get it to charge. When I bypass the regulator I get 19 volts so I know the alternator is working. Any insight would be welcome as I have pulled the motor, painted the engine bay, and put the motor back in less time than I have spent on this dam alternator. My only other idea is to replace the regulator if I can find a part number for it.
Thanks in advance
Dave
Thanks in advance
Dave
