Help with build sheet
racerdave
Cape Coral, fl
So I'm trying to learn as much as I can about my new 1968 Barracuda. I have the build sheet (see attachment) and am trying to decode it. I've searched the archives but everything I find seems to deal with the fender tag, and then most of the information is for 1969 or later. I apologize for my computer skills, but am I missing something? Is there information on our forum with the info I'm searching for? If not any suggestions on how to decipher these numbers?
Thanks in advance.
First thing to remember on a build sheet...if there is a number under the character, your car has that option! Now, it would be best to get yourself some of Galen's White Books, as they will run down every line and box of the build sheet! Some of the lines are self explanatory, such as the rear axle for example...if there is a number under the Suregrip box, your car has a suregrip! The number in the box is the last number of the 3 digit option code! So, you would take the first 2 digits printed above the option box, add the number typed in the box at the end, then look up that option code in the white book! It will then tell you which rear end you should have, the ratio of the gears, and of course since there is a character typed in the Suregrip box, it has a Suregrip!! Get the idea??
If I could read that build sheet a little closer, I would run it through my books! Maybe I'll try to bring it up on the big computer! Geof
Every Mopar nut should have a set of Galen's books. They are full of endless information.
Here's what I come up with from what I could make out from the attached photo.
Paint and style 27-29: I think it says SS if it is color is yellow 1= one color
Stp 31: 1= Horizontal black stripe
UDF: I think it means upper door frame . I don't have that number in my book
Trim 32-34 : H= high, 5 = bench seat split, x= black
Engine 37-38 : 4= 318 , 1= with a single 2barrel
Trans 39 : 5= torqueflite
Axle 40:1= 2.76:1 ratio
408 : if it's an 8 in the box it's a sure grip ( number in box not real clear)
radio 42 : 1 =am radio economy
Tires 43- 44 : 27= D70 x 14 white wall steel belt
brakes 451 :1= power brakes
Steering 456: 6= power steering
HD brakes drum/disk: 47 -6= heavy duty 10 in. drums
Dual horns 480: 0 = yes dual horns
Cigar lighter 487: 7 = yes
Floor mats/ carpet 50 : 3 = carpet
Map & courtesy light 511- 1= yes
Ignition time delay light 512: 2= yes
glove box light 514 : 4= yes
Ash receiver light 515 : 5= yes
Trunk light 516 : if it's an 6= yes
Turn indicators fender/ hood 517 : 7= yes
Tinted or clear glass 52: 1= all glass is tinted
Drip or applique 53: 5 = drip rail moulding
Body side belt 540: 0= yes
Wheel lip 548: 8 = yes
Lap belt ctr. r.r or delete 55: 7 = center rear
Hub caps or wheel covers 58: 1= deluxe wheel covers
Alternator 59: 1= 45 amp Alt.
H.D. susp. w/ w.o. sway bar 62: 5= H.D. shocks front and rear only no sway bar
691: 1 = sold expedite
Max cooling package 492: 2= yes
The last 2 lines I don't have the codes for. I think they maybe some specialty codes.
Hope this helps a little for you.
Maybe someone else has more info to add.
