Chris Hazell
Member
Hi guys, I’m new to the forum. Looking for recommendations on a camshaft. I recently purchased a 69 dart gts. The motor 340/416 had already been built and not by the owner i bought from so not exact on some parts. I had to remove the engine to deal with loose flex plate bolts so I decided to add a few things it had iron heads i am adding eddy RPM prefomers and 1.5 hughes rocker set up its a hydraulic flat tappet cam set up. 800cfm holley, single plane high rise mopar intake. I’m not exactly sure on CR I’m guessing 10:1???? Its got ross pistons with eagle 4340 crank and h beam rods. 727 with no stall 3.91 sure grip rear end. It will be a weekend cruiser i want to maximize the cam so the heads can work to their potential. I don’t mind it a little lumpy also not against adding a small stall convertor. Thanks!!!!!
