340swinger
New Member
- Joined
- Jan 16, 2009
- Messages
- 3
- Reaction score
- 0
I recently replaced the circuit boards (new) on a 340 Swinger rally dash (1970) and cleaned and checked wiring. Some pins were borken. The three pins that are on the left side that connect the dash lights, left directional and high bram indicator.
Following the replacement I encountered some problems that I was hoping someone on this site could help diagnose.
Problems I encountered after circuit board and components plugged in:
1. Headlights do not go on. However, they go on when the highbeam swich is switched on. High beam switch does not light. -never did. Note. parking lights turn on normally as well as the dash lights and dome light. (Bad switch??)
2. Gauges work OK However, the oil pressure gauge activates with the key on and pins to the H. (high) This is with car not running and key turned on. (I have the steering column down so the car is not running.) will the gague move to normal range when it starts. (is gauge OK??) Engine has new oil pressure switch.
3. The parking brake light does not light up when in Park. I beleive it worked before I messed with dash (possible fuse??)
4. For some reason the console light blinks when the lights are turned on. When working on the car I found that the bulb was removed and I replaced it and discovered the blinking. I dont know if it is connected with the dash because it did this before i worked on the dash. Blinkers work OK.
very odd maybe shorted with blinker?? Blinkers work and flashers work
everything else works OK. Wiring in dash appears original and unmolested no cuts or splices even original radio..
Generally everything works OK AC, Wipers, remaining gauges dash light etc.
