help with interpretation
No name needed
Pa.
can anyone help.
This is a 64 valiant rear. I am guessing that is the gear ratio stamped on the gear?.
323 or 291 ?
I see two numbers.
Thanks in advance.
Crappy photo, it does not show all the numbers.
If there are four more digits after the 291 for a total of 7 numbers it would be the ring gear part number.
Sorry. I'll try and post a better one.:(
Part number 2070558 is in the 69 parts book as 3.23 ratio As shown in the picture. 2070588 was wrong numbers in text.
That why I asked. appreciate the help. :thankyou:there is a 64 stamped on it also before the 7 digits.
No idea what that means.
Yeah it's a 3.23. A quick nasty way to tell is look at the thickness of the ring gear. A 2.94 and numerically lower will have a noticeably thinner ring gear to make room for the whopper john pinion gear.
Thank you.
Go to group 3 rear axle section in the 1970-71 parts catalog. Then see text page 3-11. There you will find 2070558. This number will be found in 1969 thru 1972 parts catalogs in group 3.
