Oh, for shame! We have somehow manged to desecrate 4-26 day, which I have been delighting in and celebrating since midnight...
How did we go from Hemi vs. Wedge to doing wheelies on lawn mowers??! LOL
Just think, tomorrow is 427 day. I just have to make up my mind which one. I think I'm goin for this.
Ford flathead engines and a Briggs & Stratton lawn mower engines are what is called an L head engine. Not a Hemi not a wedge it's an L head.
correct. L heads soon went to Y blocksFord flathead engines and a Briggs & Stratton lawn mower engines are what is called an L head engine. Not a Hemi not a wedge it's an L head.
But, the shim has a taper (thicker on one end than the other), which makes it the shape of a ....wait for it.......WEDGE!!that would be more of a shim than a wedge![]()
Hello! Have any pics to share of that one? I have heard that 50 and 51 were the only production years of the Crestline. I wouldn't normally ask but my dad is a fan of those and the meteor Canadian Ford cars.correct. L heads soon went to Y blocks
My old '54 Ford crestline ….. first year of the overhead valve in the Ferd….. 239 V8
I had a murray one that the deck went bad and we took it off. Being a gear head teenager I swap the pulleys front to back. That thing would fly I bet it would go at least 30mph and like you said it would ride a wheelie if you dropped the clutch.tell ya another trick of mine besides the "wire brush on a drill valve job",.. replace the cast iron fly wheel on the riding mower with an aluminum fly wheel from a lawn mower. Yes sir, them 4 hp would act like 7 hp. Rip the snot out of your fingers trying to start it and it would back fire, but I could pull a wheelie so high you thought you were going to flip backwards....you know, the those old riding mowers that the motor was under your seat. no deck, it was part of the body. no steering wheel, rather handle bars. freebies....
Flathead, of any type. How are you going to make it breathe any better? With overhead valve design, of course! Some things are just better left in the past where they belong... Being it is 4-26 day and the Hellephant is in the room, how about the best of both worlds? The Gen 3 bathtub chambers with the quench pads on each side and spark plugs on each side of the chamber. If it wasn't a good design, Stage V wouldn't waste their time making twin plug bathtub chambers an option for the maximum flow Millennium heads.
Similar but Completely DifferentOk forgive my ignorance, this post intrigued me as well. Is there a difference in the block for example a 426 wedge vs a 426 hemi? Or is the block the same and its just a simple head change?
I was always under the impression that Tom Hoover and his team used 413 wedges blocks to develop the 426 hemi and thru the design process ended up with hemi blocks. I may be wrong I'm gonna go Google it now lolOk forgive my ignorance, this post intrigued me as well. Is there a difference in the block for example a 426 wedge vs a 426 hemi? Or is the block the same and its just a simple head change?
That Ford sohc "cammer" engine was pretty amazing!Just think, tomorrow is 427 day. I just have to make up my mind which one. I think I'm goin for this.
Hemi's had more head bolts. I don't know about wedge blocks.Ok forgive my ignorance, this post intrigued me as well. Is there a difference in the block for example a 426 wedge vs a 426 hemi? Or is the block the same and its just a simple head change?
Almost... but Wedgie to be correctBut, the shim has a taper (thicker on one end than the other), which makes it the shape of a ....wait for it.......WEDGE!!
Yep, but can't post till I get homeHello! Have any pics to share of that one? I have heard that 50 and 51 were the only production years of the Crestline. I wouldn't normally ask but my dad is a fan of those and the meteor Canadian Ford cars.
Charlie Malyuke built a 383 with Hemi heads back in the early Pro Stock days. See the extra bolt hole bosses?
Close race for me on the 427. While the Cammer is outright amazing in the simplicity of its engineering and execution of design for a factory built experimental engine of that level, there is something about the brutally raw "bigger hammer" design of the R code tunnel port wedge with the single plane dual four intake that really does it for me.Just think, tomorrow is 427 day. I just have to make up my mind which one. I think I'm goin for this.
Who Invented the HEMI Engine?I was always under the impression that Tom Hoover and his team used 413 wedges blocks to develop the 426 hemi and thru the design process ended up with hemi blocks. I may be wrong I'm gonna go Google it now lol
