chasonmarose
Active Member
360 block 4.040 so 367 cubes
3.58 crank and 6.123 rods both 0.40 oversized
Kb107 pistons and moly rings 10.5 to 1 compression
Comp cam XE275HL 287/275 0.50 is 231/237 lobe 110
Holley strip dominator intake
Holley street avenger 670 carb
Cast iron heads 2.02 1.60 valves 65 cc combustion chambers ported out to 250 cfm flow.
Flow tech headers ran to magnaflow mufflers 2.25 piping.
Rear end limited slip 2.73 gears for good highway driving
727 transmission upgraded with heavier clutches.
Ignition is a 1 wire hookup 50000volt distributor
Timing is 17 initial 34 advanced and 52 with vacuum hooked.up at around 3000 rpm
This motor is in a long box d 100 and it pulls like a son *****
Just wondering if anyone has a similar combo and what HP u guys got.out of it.
Thanks!
Chase
Thanks!
Chase
