hemidavid
New Member
I have a 72 dart w/360 stroker punched out to a 408, ballanced rotating assembly, .050 cam, performer intake and a 750 eldebrock carb, electric fuel pump with pressure regulator.
Problem #1: hesitation at take off... i have adjusted the pump, trying all three positions w/ no change, played with the timing, it is at 10% initial.
other symptom: fuel drains down, filter is dry when not running. when running fuel "bubbles" in filter???
possible problem? gas tank is not vented (charcoal canister removed in build out)...strong suction when taking off gas cap...
:mumum:
:mumum:
