C130 Chief
Mechanical Genius
The engine only requires a certain amount of oil flow, anything beyond that is bypassed back into the pan. The stock pump will support factory bottom end clearances plus reasonable wear just fine. LA Mopars were never known for oiling problems (unlike some Buicks for example). If you have one, no harm by running it. But it's overkill and will use a bit more power to operate.
