Krazed
I need to get a new crank as oiling issues destroyed the last one. Thankfully, the rods turned out ok but the mains will need a line hone which will get done this week.
So, I ask you. Given the prices of forged 340 Cranks..
What would it take to go Cast crank instead? Just balancing?
Also, what could I do to piece together a stroker kit? i have Eagle H-beam rods currently in great shape. could i get away with just buying new pistons and a cast stroker crank? What's the reliability these days with Cast components?
And lastly and most importantly: Where can I buy this stuff the cheapest? I'd get it balanced in town.
Current engine: (or previous if you will)
1968 340 block 4.070 bore
Edelbrock 340 Heads. (Yes, the 65cc heads)
Speedpro TRW-L2316F30 pistons
Eagle H-Beam Rods
Previously Forged 340 stock crank
Lunati 60403 Cam (NEw in box, can still return to summit)
Let me know if you need any more info. My mind's all in a jumble at the moment so i may be missing key information.
Thanks!
Edit:
I guess the better question is: What would you do?
Eagle H-Beam Rods
Thanks!
Edit:
