Holley decoading
Snake
Mopar Nut
Belleville Canada
Hi guys heading out for a bit,no time to look theases numbers up.I got a buddy who has 2 holley carbs he is not sure what they are and me to.The numbers he has are from the top right corner were they should be first one 1150-5 second is r8 4011-2.Could someone look thoes up and let me know thanksss.
Did a quick search on the Holley site and found the one R84011-2 is a model 4010, it is a 750cfm carb, the renew kit is part # 37-1541, needle & seal part # is 6-504, primary main jet and secondary main jet or plate #122-75, power valve #125-65, primary pump nozzle size is 0.035, secondary spring color is purple, Model 4010 Airhorn Gasket Part # 108-63, primary venturi diameter is 1-1/2, secondary venturi diameter is 1-1/2, primary throttle bore diameter is 1-11/16, secondary throttle bore diameter is 1-11/16...........
lol.....queen of the search!! :king:
Thoes numbers he gave me are goofy,cant find them no were.I am not going to buy one with out numbers I can go by.Thanks for the help.Even with the link you got me nothing.
r8 4011-2 is on that link.. just have to look for it.. its a 750
Ok i found the # 4011 and a renew kit is only 27 bucks.I just did not scroll down far enough.Thanks for the help guys.But i did not see the 1150 and looks like geting a kit is harder for that carb# says carquest.he could not find the # either.
Are those numbers off the airhorn? They sound like metering block numbers to me.
I looked all thru the holley site and didn't find anything on what the 1150-5 is, but Holley has on-line help. Just shoot them an e-mail and see what they can tell ya. :)
