cookietruck
Every time you go smaller on the MAB you make the booster come on later.
And the larger bleed will delay the start of the booster.
which is it?
I’d look into a chassis dyno in your area........ tune for power....... bring the old main body with you, and some notes on how to put that carb back how it was when the car went the quickest/fastest.
In fact, that’s probably the place to start.
I’ve tested a number of home brewed carbs on the dyno over the years....... some have been so far off(both from a power and/or fuel curve standpoint) that no amount of jetting or air bleed changes were going to fix it.
They needed more reworking than that.
The best luck I had with building a carb from readily available parts was the original Proform HP 750 body, using stock Holley 4779 metering blocks and a plain Jane 4779 type baseplate.
I built a few of those, and they required minimal tuning to get dialed in.
I built a similar carb with a Holley HP body, QFT billet metering blocks and baseplate.
I haven’t had a suitable candidate on the dyno I could use to dial it in....... so at this point, it’s still an unknown.
When we were selling BG stuff, and the Demon carbs........ I found the calibration of those things to be properly set up for.......almost nothing.
The Speed Demons in particular always seemed to have idle, driveability, and wot fuel curve issues.
Often all three!!
It got to where if I was going to be using a new one on the dyno for a build we did, I’d just modify them for adjustable air bleeds before ever being run.
By that time we had a better handle on what changes to make to the baseline calibration so they’d be closer to “right” from the start.
Some of those things as they came ootb were particularly bad.......they’d hardly even run.
Wouldn’t idle, super lean at wot, headers start glowing right away at part throttle, etc.
But......they looked good.
Eventually, it just got to the point where they were just more trouble than they were worth........ and we stopped selling them.
which is it?
Got over my skis. Now I have to think about it for a minute. I need new glasses and any more than about 10 minutes on here and I start getting a migraine.
A smaller bleed will start the booster sooner, and the fuel curve will turn rich sooner.
A larger bleed will start the booster later and lean the fuel curve sooner.
I hope that's right.
I was assuming he’s using the Demon
3 emulsion hole blocks.
I had the day off and wasn't on call, so i slipped out to the track and did some testing. no timing equipment up at the track. just the track surface to make some stomps on. If i just need one i will sneak out the back road. but i wanted to string a bunch of them together.
This is the the same plug i posted above. pulled it off the trailer and let it idle, nothing else until it was up to 180 degrees(were my cooling fan turns on. shut it down to Pull this old plug out for a new one
View attachment 1715367898 View attachment 1715367899
With the new plug install, i made a stomp down the track and clean killed as best i could. pulled plug out.
View attachment 1715367900 View attachment 1715367901
drove back to the pits and pulled the plug again
View attachment 1715367902 View attachment 1715367901
2nt and 3d stomp when i pulled the plug i cut the picture. didn't figure this out until i got home.
The last one is hot lapping! I did 3 runs back to back and then clean kill it at the top end to take these pictures
View attachment 1715367904 View attachment 1715367905
That's as accurate as i can get Sorry some are blurry............what do you think of the fuel/jetting.....timing....heat wrange........ i want to hear all the appinions even if they differ one from another.
View attachment 1715367903Disregard this one.
Thank you for that I called the tech line and from my indications to them they recommended one heat range hotter.Call the NGK tech line. Those guys will get you straightened out.
How Can I Get Technical Support?
Hmm! now that's a question i have been meaning to ask.
At what G force or 60 foot time does that become important.
To answer your questions rear pv blocked, NO jet extensions in the rear.
Makes you wonder why they went out of business lol.
The specs show those blocks to have the upper two holes at .031, and the lower at .033, whereas the original 4779 blocks that I used with the old Proform bodies would only have two holes at about .026.
That’s a pretty big difference in the emulsion package.
I run mid 1.7XX i have ran one 1.6 (1.698) in the real good air day we had a while back.You should run jet extensions on anything that cuts better than 1.8 60ft IMO.
