Holley sniper?anyone good with tuning these?
I got my car to start but won’t run. Need help
That’s where I would start.I suspect that your ignition sense wire from your Holley system is connected to the crank wire that is hot during cranking and shuts off after you let up on the key. Connect the crank and run wires together and all should be good.
I remember researching all the posts here (your posts) and FB as well as the web for a couple years before I was ready to install my FiTech. So when I did finally start mine it fired and ran from the get go. Thanks for all your posts, big help for sure!Had the same thing happen with my Fitech
Happy to help I get plenty of help from here as well.I remember researching all the posts here (your posts) and FB as well as the web for a couple years before I was ready to install my FiTech. So when I did finally start mine it fired and ran from the get go. Thanks for all your posts, big help for sure!![]()
Holley sniper?
When you mean won't run, how long does it run? What tach source are you using?
Does it fire for a brief second and immediately stop? What are you using for ignition, and have you eliminated the ballast resistor?
What have you done to troubleshoot this? You tried simply giving it some throttle?
What procedure did you follow for setup? You can download all the literature from the Holley site
Make sure that the wire that senses the ignition on is staying hot during cranking as well as when you let off of the start position. I know that there is a "crank" wire and "run" wire on the bulkhead connector. The crank wire supplied 12 volts directly to the the coil + went cranking and the run wire would supply voltage to the ballast resistor and the ballast resistor would supply a lower "run" voltage to the coil after letting off of the cranking position of the ignition switch (this protects the coil). Typically you would have to connect both of those wires together and use that as the ignition on sense for your fuel injection system. Ask me how I know this
OK did you make sure the "small red" (red white?? forgot) swtiched by ignition is actually getting power in the "run" position.
You have an electronic tach? Watch it as it runs and dies. You can get a clue if it is getting power/ ignition triggers
What I mean is, watch it when it dies. If the tach drops right to zero quick, you are losing your tach trigger. If it falls "with" engine RPM, then something else. Might give you a clue where to look
I posted a suggestion on your build thread. If you want I can talk with you on the phone and see if we can figure it out. Also I will need you to email me your current tune and see if the parameters are set correctly.
R u running out of fuel? Pump good? Pump running while the motor runs? Kim
It can't unless it is getting enough air. Check throttle blade(s), vacuum leaks, and whether idle solenoid is stuck open
What did you do to get it to run?
