Just wondering if anyone has any pictures of their Holley red pump or similar style fuel pumps on their early 70s A body. I’m trying to find the best location to mount my new pump for best performance. Thanks in advance
I had one mounted on the frame rail years ago. I then switched to an automotive, and made a bracket that bolted to the floor near the spare tire well. The bolt on bracket is much better. You need those pumps at a low spot. They are pushers, not pullers.
Okay great, thanks! I mocked up a bracket the other day mounting it off of the spare tire well that dropped the pump down and positioned it at the bottom of the tank, so I’ll most likely use it. There’s virtually no room near the front of the tank to mount it anywhere
