thanks, and it isn't over until I get 'er to the strip and post an E.T. slip !I find your curiosity produces both entertaining and informative threads. Thank you 318willrun
yeah, I didn't do anything but drop the carb on both intakes. Could be that it was, by chance, better tuned for the cast. I know with more runs I could have played with it and somewhere picked up 8 hundredths of a second to match the 14.95 time, but I don't think on this day I was going to get my 2.3 mph back.I'll guess you have something going on with jetting or fuel delivery.
I think both days temp and humidity were good. I did have a "slight" head wind with the SD, but it seemed most racers were running the same MPH. No way to ever get it perfect, not even on the same day as time changes the condition. I think the days were very comparable.Weather differences?
Keep in mind, each SD is majorly designed differently per different engines. The small block mopar SD has ports smaller than the eddy performer and weiand action plus, and absolutely no bigger than a 273/318 heads. If you look at the gasket match markings in the pictures I posted above, them were with the 318 gasket. This particular intake was really meant to stay under 5000.I ran a Holley SD on my 351-C powered dirt car for two years...great performer up to my self imposed 6000 rpm redline...
I like to say dual planes use a 100 cfm's more.... IF a carb is too big, it's usually off line that is slowed, and in my case it's where I picked up. Also, the SD intake isn't the "normal" single plane intake. Big plenum and small runners, it's designed for 318's and the street.No thread derail intended but, I've heard you can use (should use?) a smaller carb on a single plane because the large open plenum lessens the vacuum signal that the carb sees. Just thinkin' out loud.
I'm not seeing that being the case..... airflow is the same, and carb restrictions are the same. Sounds like some mixed info, or a cause-and-effect that is being attributed to the wrong thing.No thread derail intended but, I've heard you can use (should use?) a smaller carb on a single plane because the large open plenum lessens the vacuum signal that the carb sees. Just thinkin' out loud.
The article (wish I still had it) made sense to me, but I know I won't be able to explain it in text. How about this; If you knew you had a perfectly sized carb on an engine with a dual plane intake, and wanted to try a single plane, are you certain your carb is still the perfect size? (adj. and jetting aside) Not arguing, just asking.I'm not seeing that being the case..... airflow is the same, and carb restrictions are the same. Sounds like some mixed info, or a cause-and-effect that is being attributed to the wrong thing.
If I ground down the unused mount, I could ditch the 1 inch spacer. I'm positive if I do a little tune/test, there would be a little more somewhere, someplace with the SD.I like the SD. It looks better.......and its almost a wash? Look at your weight savings and coolness factor. Wonder if there is a mileage change?
