Holley Strip Dominator
jtkaaa07
BossMan
Neenah Wisconsin
Just getting some of my parts together for a new motor in my dart. Just wondering who has used one of these intakes and if they liked it for street use. I had a buddy run one in the 80’s and His duster was a beast with this intake, so I thought I’d try it out.
I made 550 hp with one on my 427 BBC. Great intake, if you have a cam at .245/.255 @.050 and a 4000 stall converter with 4.56 gears.
I ran that intake on my Dart Sport 360. But it was race only with a lot of gear, converter and cam duration.
Thinking quite a bit of cam, I’m running 3.91 gears so that shouldn’t be an issue. Should be 4 gear by then too, no more automatic for this guy
I picked this one up for a song, so I’m not out much if I’m not happy. The guy had a LD 340 aluminum intake too, I’m still working on getting that one.
Well, it is a race oriented intake. So be prepared for cruddy low rpm driving. If your going to have a decent cam in there with your 3.91’s, your going to need a decent stall converter to go with it like Fisher was saying.
You didn’t mention what cam you want to run or the engine displacement.
The MP - M1 is an upgraded version of that intake with a spreadbore carb pad for the TQ. I’ve run that.
408 on the cubic inch side, haven’t decided on cam yet, I guess I’m up for suggestions on that too. Was going to talk to engine builder and see what he thought on cam maybe too
With a 4 speed and 3.91s behind a 408 and a 4 speed, you should be thinking about a large solid roller.
Or a large solid at the least. Though a little pricey, I like the roller idea better.
What heads are on top?
It will be fine and even if its not perfect for your particular combination a 408 has enough cubes to overcome whatever loss of torque you may experience compared to a dualplane anyway.
