22dog22
Problem started with past Sunday night central air was, on was in the 90"s took notice that the out side unit running but no inside fan running, Trane system about 22 years old [ just found out] i check outside unit was just starting to ice up, i turned off the power so no more damage to the outside unit, today Tuesday was able to have service tech out to take a look, air handler motor is fried, ok will have motor replace all in for about 900.00, i was going to up grade next year to H.V.A.C, for heating and cooling, so while tech is here have take look for what i need to up grade takes a look at the main panel box states you have a big problem
ZINCO panel box, states they are very very unsafe would need to replace before or at time of new system install they would not work with what i have due to a big saftey issue, Does any one have information about these panel box ? i have not had any problems but all over the enter net bad bad things are said, so to up grade i am looking and new H.V.A.C and new panel box, was told around 25,000 - 30,000 for all work , i will look at getting other price quotes for the elertrical work and A/C work , ideas thoughts ??
