hemitheus
19? Plymouth Scampenstein
this is going to sound insane... but can someone post up with pics on how to release the hood on a 64 valiant (presume cuda is the same)
Don't have a picture. Not sure if the Valiant emblem looked the same in 64 as it did in 65. On my 64 Barracuda you stick your finger into a slot under the front of the emblem on the front of the hood. There is a little lever there that you pull down with your finger. This releases the primary latch. Then you lift the hood a couple of inches, reach in & move over the safety latch to open the hood the rest of the way.
Don't feel too bad. I've seen quite a few people who couldn't figure it out.
True I am sure if we have a hard time finding it they would also.Keeps thieves out of engine compartment. :-\"
Check out the picture below. Slide the rod in the center of the picture to the left, then when the hood pops, slide the safety to the right.
i told u so lolThat's definitely a bit different than the '64 Barracuda latch I described.
