Horn question
oldirish
Georgia
I have a 72 Duster, it's wired for the low and hi horns. I have one horn and I don't know which one it is. Image attached
Any help is appreciated, I'm looking for the other horn.
As noted they are marked right on them LO and HI... and factory install, at least on a B body is the Low is the higher mounted one, High the lower mounted one.
Actually, on this car the mounting screw holes are side by side. You can see the second set of holes in the pic I attached on the original post.
