Hot Rod Small Block Stuff
whitepunkonnitro
Murfreesboro Tn
Rating - 98.2%
162   3   0
*360 Block...Fresh from machine shop. .030, ready to clean and assemble $250 (pick up only, or delivered within a reasonable distance of Nashville for gas money)
*Mild ported 2.02 heads, complete $250/pair
*New In Box Mopar Performance .557 Cam and Lifter set $125
*Weiand Tunnel Ram. Comes complete/assembled with a pair of 600 VC Holley Carbs, linkage and fuel lines. $500
*Adjustable Rockers. 273's upgraded with jam nut adjusters. comes with shafts, spacers and pushrods $100
* Accel Race Dual Point Distributor $60...Add Taylor wires for another $20
* Windage Tray (340, slotted to fit 360) $50
* 360 crank, cut .011/.011, ready to go $100
PM me if interested in any of this stuff, Thanks FABO
Pics of heads available? How much time on heads?
Any flow numbers for the heads? How much lift are the springs rated for? Include rockers or no?
Not a clue what the flow numbers might be...the heads came to me bolted on an engine a few years back, and have been sitting on the shelf since. Rockers?, sure, I'll throw in a set of standard stamped rockers and shafts if you buy the heads.
