how can i beef up my 318 performance
customduster73
Custom73
hendersonville nc
what are some things I could do to beef up my 318 small block performance? im new to engine compartment. Learning as I go. any help or advice would be great. also if I should just save some money and get a 360?
Above, I see great minds think alike! Both posted at the same time! LOL!
Depending on how far you want to go, the first step is to make a plan and stick with it.
Moving to a 360 is a catch 22 since the money you could spend on a hop up or mild performance gains would go to getting and then machining the 360. (If it needed the work) It can be a good chunk of coin depending on the parts used and what your target goal is. Still, a junk yard 360 plus the cost of a B&M corrective balance flex plate and then maybe engine mount(s)?
As a general guide line;
(This is a general list and sometimes there not so easy to do, but here we go!)
Stage 1, bolt on parts
(From top to bottom)
Upgraded air cleaner, stock 4bbl. or open
Carb to a 4bbl., Holley, Edelbrock or TQ (TQ must use the proper intake or adapter!)
Intake manifold to a 4bbl. General to mile performance Holley or Edelbrock should be 600-650 cfm's.
Headers into a 2-1/4 exhaust (mild) or 2-1/2 exhaust (good for power!)
An "H" or "X" pipe would be a plus in the system. Summit racing or Jegs has inexpensive header back kits with and without mufflers.
It is my opinion that the headers and the exhaust kit be purchased at the same time and installed at the same time as well. The X or H will require some time to splice in, so, take a weekend and perhaps have a buddy around.
Upgrade the ignition, distributor, wires, and ignition box. For a basic plug and play, the MoPar Chrome box or a FBO unit is excellent.
Stage 2, bolt in parts and machine work
A cam is an arguable part for stage 2 since often it is best to do a cam change when the intake is off. The vary-ing cam profiles must work as a package with the rest of the engine and drive train. When you purchase you cam, save money up for the whole kit. (If available)
The basic kit is cam and lifters. But I would option for the timing chain, valve springs as well as the retainers and valve locks etc...
Heads;
Stock heads can be great performers. Putting money into a stock head with larger valves and/or porting can yield great results but you will have to know if the castings final stage of work is worth the price vs. aluminum heads. (Ported or not.)
A stock small valve 318 head can motivate a A body into the 14's, no problem.
Going to a stage 3 is rebuilding the engine for more serious gains. If you want to push your car into the 12's and faster, it is going to more than likely need a rebuild with a few upgraded parts to insure long life and not a short putting bending or braking parts. While possible to run 12's on a stock short block (and heads if it has to be that way) I suggest not to do this. The engines are old with probably unknown history.
Also at this point, it becomes an expense that a 360 is probably the better bet for ease of motorvaition. (Sp?) less cam, not such a snotty rough idle engine, more torque and HO delivered quicker in the rpm range.
To do a 318 at this level, you pretty much have to want to do a 318 that way.
I have a performer 318/360 intake port matched to the heads. Carb is a thermoquad. Cam is 210° duration @ .050 and .450 lift. New timing chain is a must! Even if you keep the original cam. The original nylon tooth timing gears are junk. I have a stock electronic distributor and orange box. I am running stock exhaust manifolds and dual 2 inch exhaust. I don't have any time slips for that Dart but it is way faster than a stock 318.
Let us know the kind of performance gains and money you are willing to spend. It's better if you talk what kind of performance in the manner of :
1). How the car will be used (highway, mostly street, etc. etc)
2). How much more power you're looking for.... Or an E.T. goal ??
3). Just don't throw out a Horsepower number because it sounds cool.... "400 horse" ...lol
360 is a great choice, but if you already have the 318 and want to work with it, they have a lot of potential. This is the age long argument here. Although the Ford guys don't throw away ALL there 302's in the fox bodies for 351's or stroker 347's, and yet they make them 5.0's fly (and love 'em).... Us mopar folks (commonly speaking) throw away the 318's. Of course 340/360's offer more upfront, but in no wise does this mean the 318 can't get it done. A four inch crank in a .030 over teen is about 400 cubic inches.... and plenty of guys have done this and gone 10's in street cars.
I wanted to say that, But didn't want to be the first.
There is just no comparison. For street performance,you couldn't trade me a smaller sbm unless it was stroked. I'll never go back.
Even if you stroked it i WOULD waste my money...
