How long should a car hold vacuum after being turned off?
Are we talking about the A/C system or the booster,as you are not clearly stating what your problem is or if you are sure what is normal or not,mrmopartech
Sorry, the AC system. It holds a vacuum for only about 30 seconds after the car is off, then it defaults to defrost.
That's what I thought. I checked the check valve by blowing/sucking. Must be a cracked hose.
