4mulaSvaliant
Im getting tired of bleeding the brakes at this point!
Ok I have always went about bleeding brakes the "old" way: 2 people, one pumping, one cracking the valve open.
Well I spent a good couple hours last weekend doing it that way and eneded up with only about 1/3 away from the floor (total pedal travel) YEAH NOT GOOD!
So I tried what I have heard worked good for a friend which is the handheld vacuum pump. So I went about it that way last night and it didnt sem to get any better.
I am figuring the pedal should be pretty solid feeling at least half way to the floor.
So on this next attempt I will use what I found to be really good, when I did my old Jeep a while back. I bought some of the one-way-bleeder screws.
If you havent seen them yet, they have a check valve inside them. On the Jeep I just cracked it open and pumped away! Unfortunatly I have to watch carefully because my master cyl. is sooooo small.
Anyhow does anyone have any more advice I am getting tired of bleeding brakes and not getting to run it around a little.:angry6:
