How much head do you need?
greymouser7
Vagrant Vagabond “Veni Vidi Vici”
78002 down the road from Atascosa, Texas
Cylinder head flow for the crane 693901 camshaft?
1.78 & 1.5 valves good enough?
Goal is long distance driving
800-4800 operating rpm, 3800 pound car, 2.76 gears, manual trans
Basic Operating RPM Range:1,500-4,500
Intake Duration at 050 inch Lift:204
Exhaust Duration at 050 inch Lift:216
Duration at 050 inch Lift:204 int./216 exh.
Advertised Intake Duration:260
Advertised Exhaust Duration:272
Advertised Duration:260 int./272 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.427 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.454 in.
Valve Lift with Factory Rocker Arm Ratio:0.427 int./0.454 exh.
Lobe Separation (degrees):112
I wouldn't get too worried about head flow; that is a very mild cam, only slightly larger than a stock 360 2bbl cam. Years ago I put one into a 1965 Hi-Po 273 that also received a set of 302 heads, worked out very nicely. Go for it!
That's an excellent cam for lo compression engines...even 340, for street driving.Tons of torque, smooth idle, pulls hard and gets excellent mileage.
Not a quarter mile piece.All but the drag racers will like it.
