How much should I be paying?
JTG
How much should I be paying someone selling a complete L & R 10" SBP front drum brake setup which includes the hubs with wheel studs, backing plates, brand new brake cylinders and new hold down kits, new shoes, and the brake drums are NOS.
Used 10" drum setups are cheap since so many change to disk brakes. I paid ~$40 for 10" drum setup w/ spindles and other parts (p.s. gear, I recall). Add in the value of the new parts. Check rockauto. I recall ~$6 ea for wheel cylinders and $12 for a "hardware kit" (for both fronts) at Autozone. Shoes ~$15, or more for top quality. Front drums are ~$22 ea for decent Centric. I don't know what NOS drums are worth. BTW, rear drums were recently un-obtanium, thus $250 ea on ebay, but they started making them again so ~$35 ea. You can also machine front drums to work.
Whatever you installing these on will need 10" drum spindles. Included? If you currently have 9" drums, your spindles won't work.
Thanks tekslk and Bill, for the reply, helps give me some insight.
